Transmission tuning: Shift points
Hey guys, I want to change what rpm's my tranny shifts at. Do i need to just change the rpm's? Or the speeds? Both? Any help would be appreciated. Thanks
You can turn the WOT shift tables off in EFI Live. Should be able to do it in HPTuners as well I would assume. Then, all you have to do is work from the part throttle MPH shift tables.
To turn 'em off, you just set the WOT Shift Mode thresholds to 100%.
