how much horsepower are you putting down with stock MAF
just like the thread reads how much horsepower are you putting down on stock MAF or ported.
Im shooting for 700whp
stock maf is limited but you can rescale you should check this book outhttp://www.amazon.com/Engine-Management-Advanced-Greg-Banish/dp/1932494421/ref=sr_1_9/103-2413052-3214264?ie=UTF8&s=books&qid=1185511434&sr=8-9
stock MAF tends to max out at around 650hp ... are you planning on hitting 700 on motor or with boost? If boost then I would investigate using a custom 2/3 bar operating system which uses speed density instead of the MAF. (MAF also maxes out at around 7-8lbs of boost)
