so if i spray a direct port 125 shot i dont need to have it tuned???correct???
i'm doing full bolt ons and cam
doing direct port kit for a 125 shot
i will be tuning it for bolt on and cam etc. will i need anything to advance timing or w/e?
N/A - Head cam cars usually like 27~28* of timing
Rule of thumb for nitrous - pull 2* of timing for every 50hp
Translates to 22~23* of timing for when you're on the bottle. You can get a timing tuner from Full Throttle that will pull it out without having to change the tune for a few hundred $$$.
^^^ditto... for a DP setup you are adding the fuel and nitrous yourself, however you're not doing anything with timing. To be safe you want to retard timing. (one thing you could do is have your IAT adder table tuned such that when certain temp values are read it pulls timing... then wire up your nitrous switch such that when active, the PCM reads this lower temp, thus pulling timing but not affecting normal WOT driving)
Originally Posted by 99DWPTA
so if i get a timing tuner when its on the dyno will they figure out whats the best degree to set it at??
Assuming the tuner knows what he's doing when it comes to nitrous applications, yes.
also who makes them tuners
It appears you need to re-read my post. (FULL THROTTLE)
