Building the VE tables for a SD tune
Old 08-06-2007, 12:03 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Default Building the VE tables for a SD tune
What is the best way to build the initial VE tables for a SD tune?
Keith
Old 08-06-2007, 12:10 PM
SSpdDmon's Avatar
Find a file from something similar to start from.
Old 08-06-2007, 12:21 PM
ls1290's Avatar
OK, does anyone have VE tables for something close to this?
- 402 CID motor
- TEA Stage III 6.0L heads flow: 70 @ .100', 144 @ .200", 213 @ .300", 266 @ .400", 305 @ .500", 322 @ .550", 333 @ .600"
- 236/245//598/608//115 cam
Keith
My90Iroc's Avatar
Only copy the VE table and even at that you need to watch it. You never if the file you're using was done correctly and if it'll match up to your setup. There are lots of other factors that can influence ve values.
Setup your IFR correctly and tune slowly and conservatively. I'm assuming you're going from the 383 to the 402/F1 setups in your sig. If so adjust your displacement per cylinder. Stay out of boost as much as you can until you get a feel for how far off the ve you start with is.
Old 08-06-2007, 01:36 PM
LS1Tech Sponsor
Slowhawk's Avatar
Just use the stock file and maybe add 10% to it. Start tuning right from startup.
Old 08-12-2007, 01:19 AM
ZL1Killa's Avatar
PLAY WITH IT!!!!! WWWWWOOOOOOHHHHOOOOOOO
depends on how much after stock you have gone... might need to go more than 10%... just gauge it and have fun!!
