Throwing P0122, P0305, P0449 after NX wet install... lil help?
I threw the following codes:
P0122 Throttle Position Sensor low voltage
P0305 couldn't find what that is but I think its misfire on cylinder #5 (which I think I fixed this code but haven't erased it yet because of a spark plug issue)
P0449 Evaporative Emission (EVAP) Vent solenoid control circuit
Now, I tapped the TPS wire for my TPS sensor switch(NX) and that is the reason for the low voltage but why is it lowering the voltage now that I have a switch reading it?
As for the EVAP I don't even know where to begin on what is wrong but is it because the PCM isn't seated correctly? I had to remove it to tap the 10# white tach wire for my RPM window switch (NX) ?
Now I am using either 14 or 16 gauge wire for my nitrous setup, is using this big of a wire stealing the voltage from the wires I tapped, which I are obviously smaller ?? Let me know what you guys think I should do THANKS!!!
Originally Posted by ChaseSS
you just let your SES light stay on all the time??
