Narrowband Output on UEGO
Hey guys I've done some searching on this, and it seems that the Innovate Widebands can support a narrowband output. I'm on stock manifolds and cats, and if at all possible would rather not weld in another bung. So my question to you is whether or not you can use the connector from the factory 02's and splice into the wideband sensor so both will work? Thanks for your help guys.
Yes you can simulate a narrow band. The easiest solution is this:
https://www.casperselectronics.com/M...Category_Code=
man thats handy....but unfortunately i race monday and doubt that will get here in time. im pretty sure the factory harness can be made to work with a few butt splices correct? thanks guys. oh and also, where are you running these wires through to the interior for the gauge? i already have a 6 AN nitrous line, and all my nitrous wiring running through the grommet behind the PCM so i was hoping i could get in in there through maybe the tranny shift gate or something....open for suggestions on that one. thanks guys
