ASR and ABS Inop
ASR and ABS Inop
After rear gear swap on a 4-channel rear and car. We just changed the ring and pinion, but since we also did a head and cam swap I did start while the rear end was apart and the axles were out. Do I need to reset it or could I have a problem? The car is not on the ground yet as I still need to hook up the Y-pipe (long tube install also) and there is an inch or so of fresh snow on the ground.
