Revisiting Shift Points - N/A Compared to On The Juice
Ok, first things first. I'm having trouble really bringing my shift points on my 1-2 shift down, I keep dropping the RPM and MPH a little each time but I'm still shifting too soon.
Then I went for a juice run and the 1-2 shift came waaay early. (N/A I was actually shifting at 6600 and juice runs were actually shifting at 5800 WTF!!) To make it worse, just 1 juice run shifting up around 6400???
Is there other things the PCM takes into consideration for shifts? Ideas, questions, advice??
Thanks!
Mark
Thanks!
Mark
Restricted User
Re: Revisiting Shift Points - N/A Compared to On The Juice
I may be wrong, but I think you want to lower your mph for the shift and raise your RPM. It will shift at the first of the two, or something like that?
Good-luck.
Good-luck.
Ok, so it's supposed to command the shift with the first parameter it hits or do both have to be met?
Thanks!
Mark
Thanks!
Mark
Restricted User
I believe it the first one, I could be wrong but if you set to shift at 50mph/6300prms, then it should shift at 50mph.
