EFIlive ??? '01Z06
EFIlive ??? '01Z06
Using EFILive V on '01 LS6.Pid = DESIAC.Raw data shows 90 -120.Are these iac "counts" ...that should be between 30-40?? Also Pid "GM LS1 IAC" is pegged at 310-what's up with that??? Thanks for all and any help!
joel (Bink)
joel (Bink)
Re: EFIlive ??? '01Z06
IMHO,
your scanner should not be showing IAC for a C5 Z06 because it does not have IAC, it is all controlled by ETC, drive by wire.
F-body has a stepper motor for IAC,
C5s uses TAC module that controls TPS and idle.
JR I realize the PCM controls the idle air but it (EFILive) is measuring IAC- or whatever you/they might call it. In fact I have adjusted my IAC park at 60*(25 gm/sec) and 80*(31.5 gm/sec) and these DESIAC values have come down and the car is holding an idle with my new cam- It is still stumbling as the temp transitions through 81*C.
Any help is appreciated. Ideas?? Thanks in Advance!
joel(Bink)
joel(Bink)
