ecm oil pressure
thanks for the info. my problem is i put an ls1 into my s-15 sonoma and it will start and then die. i replaced fuel pump installed a regulator, new fuel rails ,injectors,fuel press. is at 62psi durring start up.the engine will fire then it die's and then the only way to get it to fire again is to hold the accellerator on the floor. but it won't stay running. any idea's?
