Is this normal..pics inside??? Please respond fast!!
Hey guys,
Do this look normal?? I also have a couple other pics of corrision forming where it plugs into the computer.....Any help would be great!!!
There really isnt a whole lot of problems....it sometimes misfire but got that out by changing o2's the only weird thing it does...is some mornings it wont start...Then when it finally turns over acts as if I reset the computer..wont idle and will just die....I was just wondering if that looked strange? I didnt think the comp should have corrosion and black on it and the connectors??
Clean it with electronic cleaner and put it back. I really doubt it has to do with the computer though. Check the throttle body sensor. If there are problems sometimes an erratic idle happens.
Looks like water is getting into the plug somehow.
Did you pull any pins from the harness?
If so you need to fill the hole with either silicone or a plug. Then make sure when you clean your engine bay to not spray the computer.
When water is in that computer you are directly shorting pins. that is why you are getting buildup of that curosion.
I have no idea why water would be gettin in there no pins have been removed and I never clean my motor with water...The car does get drivin in the rain sometimes...maybe the seal was not settin down right....??
