PO106-how to get rid of it?
Hey guys, throwing the Absolute manifold pressure/range performance code (po106), what is it and how do i get rid of it, its been coming on since the cam install...
Thanks
Thanks
Re: PO106-how to get rid of it?
MAP sensor is on the back of the intake manifold. Make sure it's plugged in properly and it's not cracked. Tough bugger to get to, may have to pull the intake.
I don't think your cam is crazy enough to be throwing MAP related codes, but I have heard of it happening (MAP and TPS related due to crazy cam profiles). By crazy I mean 230+ duration on 108-110 LSA's.
Good luck,
Andrew
Good luck,
Andrew
