94 lt1 turbo tune tuner cats help
Ok i have a 94 lt1 engine and need some input on a good base tune or atleast a starting point to program my stock pcm with tuner cats. i know timing needs to be pulled but how much and where at? i have a 3500 stall and the turbo starts spooling about 3400 . also what are you guys changing on the trans settings. maybe +5 line press all across the board? thanks for any input
here is a stock tune i had found. i had trouble trying to figure out how to put mine on here
http://www.monodax.com/forums/attach...aroa4stock.bin
ok as of now i have a completely stock motor ,bowl blended,smoothed and enlarged runners and chambers on the heads
3400 stall ,shift kit ,big turbo starts making boost around 3000 rpm, 3.55 gears, homemade log style headers 1 5/8 tube into 2 1/4 crossover pipe, 4" downpipe, factory 02's before turbo ,maf and iat after compressor no muffler
wanting to run 5-6lbs will be upgrading pump soon
thats all i can think about right now
