oil pressure sending unit question HELP
im not sure if this is the right section so sorry if it isnt.
on the oil pressure sending unit there are two wires. a ground and a main wire that runs back to the pcm. does the oil pressure sending unit have a power wire that is t'd in with the ground on the shrink wrap looking deal? or is it powered through the wire that runs back to the pcm?
im just cleaning up the harness on some wiring that i dont need and thought it would look better.
any help would be great
thanks.
o yea this is a 98 engine harness
thanks.
