injector scale close to stock for 36lb injectors in 422??
Old 07-30-2003, 05:52 PM
ss_girl's Avatar
Default injector scale close to stock for 36lb injectors in 422??
I'm working on tuning my new 422. I'm running 36lb svo injectors. I keep scaling down the injector scale because I'm running lean and the injector scale isn't much higher then with stock injectors/motor. Right now I'm set at 3.98 for the first cell. Stock was 3.62. I started at 5.52 with all the conversions done. I'm just curious if anyone else has had similer results. I guess I just don't feel quite comfortable.
Old 07-30-2003, 07:45 PM
red ws6 99's Avatar
Default Re: injector scale close to stock for 36lb injectors in 422??
Based on the your other post you have a fuel pressure/volume problem.
Gary
Old 07-30-2003, 09:40 PM
ss_girl's Avatar
My pressure stays consistant while cruising but my fuel trims are staying in the 15 to 17 range.
