Getting a "stumble" at PT only
I get a stumble at PT only. If I increase the throttle to about 3/4 it'll go away and run fine but if I have the throttle at a low PT I can feel and hear it stumble. My plugs are new, and the wires have all been reseated. It happens mostly in 1-3 gear.
Re: Getting a
No if it just started outa the blue, you have some other problem, unless the weather just changed. Plug wires have a double click when they go on; if you only get a single click they aren't on good enough. Maybe change out your fuel filter and air filter as well. You may need injector cleaner or new injectors. If all else fails, log everything you can think of with EFILive then study the files for anything outa whack.
