SES help
Old 08-02-2003, 06:58 PM
Dangerous SS's Avatar
Default SES help
My SES light came on a few days ago i went to dyno the car today and it only out down 318hp and 345tq wtf so we plug up auto tab and the codes were mass air low frequency i changed out mass air flow to about 3 different one they were all stock ones and i still have the same problem
Old 08-03-2003, 12:38 AM
Default Re: SES help
TTT
Old 08-03-2003, 02:35 PM
anyone
Old 08-04-2003, 01:29 PM
30thWS6's Avatar
Ever think of checking the wiring?
Old 08-04-2003, 08:59 PM
did that and it seems to be fine
Old 08-05-2003, 10:54 AM
30thWS6's Avatar
Does it have 12V to it? Does it have a good ground? And finally, does the signal wire have good continuity to the PCM? Do you have a good connection at both the sensor and the PCM? Are there any leaks after the sensor? If all this checks out, and you've tried three different sensors, then you're left with only one other possibility.
