DTC P0300 (engine misfire detected)
Old 08-06-2003, 05:06 AM
1320_PERFORMANCE's Avatar
Default DTC P0300 (engine misfire detected)
WAssup guys. jus got my car back today wit new tr224 112 lsa on a 2002 m6 and ses light came on. could this be caused by the cam? its kindah hard to tell if car is missing or not wit cam. it also has a hard time idling @ first start. any info would be greatly appreciated.
Old 08-06-2003, 05:58 AM
Restricted User
EFILive's Avatar
Default Re: DTC P0300 (engine misfire detected)
This may or may not be relevant but it's worth reading anyway
http://www.seattleautomotive.com/ckpdoc.htm
Old 08-06-2003, 09:54 AM
Restricted User
CAT3's Avatar
Yes it could be cam. Once the car stumbles, trying to find an idle, it can set that code. Did you drill the TB? I used an 11/64ths drill bit for mine. That and the predator, and now she idles good. Glad you got it back. Enjoy.
Old 08-06-2003, 10:57 AM
Ed Blown Vert's Avatar
That is normal when installing a cam. You will need to EDIT it out.
Old 08-06-2003, 10:30 PM
Thanks guys. predator or ls1 edit? prices? which is better? will either get rid of ses, and will it fix-hardtime starting @ first start. sorry guys dont really noe much bout this pcm diagnostic stuff. any more info would be great
Old 08-07-2003, 10:19 AM
Murdock's Avatar
Don't know about the predator. LS1Edit will fix the SES and hard start. Edit is more involved than using a hypertech or predator, but Edit is more powerful.
You could also find a good shop and have them tune it.
Old 08-07-2003, 01:27 PM
Restricted User
CAT3's Avatar
Yep, Predator can turn the SES off, and clear SES' anytime they are set. The Predator is a very ppowerful tool as well, just have to rely on someone else to write the tunes. Much like if you have your car tuned at a shop, they write your tune, not you. And when you mod more, you can adjust again. Depends on your preference.
Old 08-10-2003, 11:18 AM
gillbot's Avatar
I get that all the time, you need to do some tweaking to the misfire tables and you'll be fine. It's common with larger cams.
Old 08-12-2003, 02:03 PM
purevilss's Avatar
Where are the misfire tables, in Edit? What changes do you recommend for the 0300 code?
