Misfire p0300
Old 05-08-2008, 11:29 PM
BKC2006's Avatar
Exclamation Misfire p0300
I have a 99 pontiac trans am it just started acting funny.I got a check engine light on and the car has a misfire on lower rpms but if you stomp the gas down it runs fine.It seems to be getting worse as the car warms up.I have just headers,no cats and a borla muffler also their are no rear 02's. The check engine light is saying p0300.I had the car put on a snap on scanner and its saying misfire on cylinders 1.3.5.7 all bank 1. I have had a compression test done and its showed up fine,a wet test also the valve springs looked at.Their are so many posts on here and I dont want to start just replacing plugs,wires,injectors,coils that can get a bit expensive.Please if anyone has any ideas let me know.. Thanks..
Old 05-08-2008, 11:50 PM
linegtdt52's Avatar
I can help! Get me the actual message you get from the PO300 code like multiple cylinder misfire or whatever the message says.
Old 05-09-2008, 10:41 AM
02NITROUSLS1's Avatar
The "message" for P0300 says Random cylinder missfire detected in all OBDII vehicles...
Old 05-10-2008, 12:34 PM
BKC2006's Avatar
I Fixed The Car. The Front Bank 1 O2 Sensor Was Bad.it Did Not Throw A Code It Was Leaning The Car Out.thanks For The Help
Old 05-12-2008, 06:48 AM
bada's Avatar
I have the same problem. I installed a LS7 in my 1932 pro street truck. And I am running a 400 turbo tranny. Can I just go into the PCM and get rid of the PO300 code so it want come on anymore? Plus is there a difference between the o2 on the driver side & the passenger side? I have headers. So the rear o2's have been eliminated. Mine is a random misfire. The truck runs great, it just gives the code.
