Stock Throttle Body hole size
Old 08-07-2003, 06:44 AM
Restricted User
2001 Pewter WS6's Avatar
Default Stock Throttle Body hole size
What is the stock throttle body hole size??? I drilled mine out to 1/4" and now with custom tuning, it is idling too high.
Old 08-07-2003, 08:12 AM
Constrictor 98TA's Avatar
Default Re: Stock Throttle Body hole size
If its idling too high with custom tuning, then why not lower the idle?
As for your question, I believe it is 1/8". I drilled mine out to 3/16" and its been fine.
Old 08-07-2003, 10:55 PM
Cal
Cal's Avatar
You can't simply progam a lower idle speed if the hole is drilled out too big. One of the ways the computer controls the idle speed is by controlling how much air goes through. Anyway, if the hole is now too big, you can fill it in with JB Weld epoxy and re-drill it smaller. Or, my favorite method: machine a nylon bushing on the lathe with the right ID that presses into the 1/4" hole.
