08 Vortec Max CNG
Old 06-17-2008, 03:01 PM
05lly's Avatar
Default 08 Vortec Max CNG
I have a 2008 Vortec Max with a 6.0L that has been convertered to run off
of Compressed Natural Gas as well as gasoline. It is driver controlable to pick
what fuel to run off of. When running on CNG it is setting P069E in the Ecm and P2635 in the Fuel pump control module. I took care of the P069E in the Ecm with Efi, but the P2635 is still commanding the MIL through the FPCM.
Any ideas?
Thanks
Old 07-21-2008, 06:07 PM
RAZV11's Avatar
Default CNG problems..
I have the same problem with a 2007 Vortec 5.3, it has been converted to work with CNG, but a can't find a way to take care the DTC P069E or the P2635, is still commanding the MIL through the FPCM.
What can i do???
Please i need help!!!
Old 10-27-2008, 01:36 PM
Hi Volt's Avatar
Default GM fix coming soon
Contact Technocarb Equipment, website is www. technocarb.com. A fix for the GM codes is coming fairly soon.
Old 11-07-2008, 08:18 PM
Hi Volt's Avatar
The fix is done. It is a sub processor for the Fuel System Controller ( unit usually located above the spare tire). The install is a 6 wire hookup to the stock controller wiring harness, and one additional wire to your lockoff solenoid to detect LPG/CNG operation. The unit is fully weather tight and mounts by the stock Fuel System Controller module. Contact Technocarb Equipment for one, ask for Brad 604-854-6264 and he can set you up.
Quick Reply: 08 Vortec Max CNG
