predator newbie with dumb questions
Old 08-18-2003, 03:58 PM
waverider's Avatar
Default predator newbie with dumb questions
Is it safe to unplug the unit when the key in on. Instruction say nevef turn key off when unit is plugged in. Generally when is it safe to plug the unit in and when is it safe to unplug the unit? I read the instructions but still don't know?
Old 08-18-2003, 09:52 PM
waverider's Avatar
Default Re: predator newbie with dumb questions
Nobody here uses a predator? I've read the instructions 4 times and it doesn't say when it's safe to unplug. Says no turning key to OFF position when plugged in. Does that mean when you done using it to unplug it with the key turned on??? Don't wanna fry the pcm or the predator. What do you do when done using it. Unplug when key is on?
Old 08-18-2003, 10:15 PM
WS6FirebirdTA00's Avatar
ok your talking about to just take the predator out when your done?
Old 08-18-2003, 10:17 PM
Drew778's Avatar
After your done tunning or scanning I would ESC to the main menu and then unplug it, Thats what I do.
Old 08-18-2003, 10:25 PM
yeah tahts what i do too, just unplug it as long as your at the main menu
Old 08-18-2003, 11:24 PM
waverider's Avatar
With the key on?
