ok to cut power to PCM ?
i have a cartek electronic cutoff switch on my ls1 which cuts the power to the PCM whenever i use it, now can you see any problems with cutting the power to the PCM alot? i dont want to kill the PCM!
cheers
cheers
why do you have a switch that kills power to the PCM? is this so your vehicle doesn't get stolen?
no i won't see it hurting it, just everytime you do that your car will have to "re-learn" the fuel trims and such
