crappy tune???? experienced tuners help!
Old 07-15-2008, 04:43 PM
lt4malibu's Avatar
Default crappy tune???? experienced tuners help!
i sent my ECM out to get a base tune for a cam swap, now its setting codes, wont idle for **** unless i "adjust" the screw on the throttlebody...
heres my codes:
p1683 and a p0106
the 1683 is an ignition system code(usually sets in modules not programmed????) and the 106 is a MAP code, which im gonna say is due to my TB adjustment... when its cold itll start and idle sometimes then wont re-start or itll stall and it surges at cruising speeds.
the car has an MS4 and a 4000stall converter... any ideas???
