Need help to make AFR commanded low res PID
I use Hp Tuners and need help creating a low res AFR commanded PID. The one that is already configured is in high resolution and says that my computer can only function up to 24b or something like that... If you could help I'd appreciate it.. I'm trying to eventually get AFR Error % to tune my VE... I'm in SD 2 Bar also....
Okay so I was messing around with the PIDs and decided to clear last vehicle (obviously mine)... Well I found the prescious Commanded AFR low res PID but when I loaded and started scanning it didn't work on mine... If that one is not supported and the Hi Res uses too much memory then what am I supposed to do???
Well I found the answer... The "table" in hp tuners for 98 LS1 can only use 24b... I had to delete something so that I could log Commanded Afr... I deleted MAF since I'm in SD mode anyways and I deleted ECT for now just to get the commanded afr high res to work... The low res was not even compatible with my car...
