Misfire question
Old 08-09-2008, 09:51 PM
Motohead1's Avatar
Default Misfire question
I just installed some LG LT headers on my C5 and I am getting a random misfire code on cyl 3 only witch goes away after warm up. Im sure its a spark issew with a bad or loose wire. My question is how does the PCM determine what cyl is actually misfireing? Also how accurate is it? Thanks.
Old 08-11-2008, 07:23 AM
Motohead1's Avatar
Ok can anyone answer me this? Does the computer shut down the injector on a cylinder that has set a misfire code? I ask cause the car completely smooths out when the CEL goes solid.
Old 08-11-2008, 05:24 PM
TedsB4Csled's Avatar
I'd be interested in finding this out also. My missfire is not very consistent. I think it's a cracked insulator. Already found one cracked. Dam AC Delcos.
Old 08-11-2008, 06:23 PM
OUTLAWZ RACING's Avatar
By the crank position, to the fire order, I guess but the cpu is dam accurate!
