too much background noise while on dyno
Went to the dyno today, and this has happened several times at different dynos. They hookup the dyno to get the RPM readings, and have a he77 of a time just trying to get a reading. I have swapped out the stock plug wires (taylor spiro 8mm), and plugs, what else could be causing this. He said that he could not get an accurate reading because of this.
Re: too much background noise while on dyno
Can't be sure since I was in the car, but it looks like that is what he was using. wires are still all spread apart on the drivers side coil pack.
