HP Tuners forum LAUGHS at EFI Live guys..
You gotta read this:
I made a post on how to adjust WOT% like EFI Live can so I can do index racing, and they come back & tell me they don't have it because if you make incorrect adjustments, you can fry your PCM or blow up your car..
Gee, isn't that the case with ANY type of tuning one can do...
Read this:
http://forums.corvetteforum.com/show...post1566954226
Read this:
Math is just that... Math.
Gear ratios are known, tire size is known, Rear gear is known. So..... How can it be wrong?
I use that feature every day and it works great. But you have to make sure the tire size is right and gear ratio.. Which, would be wanted anyways to make sure your odometer and speedometer are accurate.....
