no way to get rid of kr without edit?.....
Re: no way to get rid of kr without edit?.....
higher octane will help if you're getting REAL knock... but if it's false knock it won't help and you'll have to try to determine the source of the "noise"
The timing from 40 to 24 isn't right... 40 is cruising advance, 24 is when you're at WOT (at WOT you probably won't see more than maybe 28 or 29 w/0 knock)
