LS1Edit V1.3 - IFR 100kPa - 20kPa???
Re: LS1Edit V1.3 - IFR 100kPa - 20kPa???
The scaling was changed to reflect the actual MAP sensor reading - the units are no longer manifold vacuum but rather manifold pressure.
Both will be equivalent *if* your barometric pressure is exactly 100kPa. If it isn't then which is correct depends on how the table is in actuality scaled in the pcm (whether this change was made to correct an actual issue or to make the interface more consistent).
