engine code p1637
Old 09-20-2008, 08:43 AM
mmorellicamaross's Avatar
Default engine code p1637
running engine code p1637, generator l-terminal ciruit, what is this and how do you fix it?
Old 09-20-2008, 09:55 AM
2001NBMZ28's Avatar
Check the red wire and connection to the alternator. More info here: www.gearchatter.com/viewtopic8959.php
Old 09-20-2008, 10:59 AM
Thanks your probably correct I replaced the alternator about a month ago.
Old 09-28-2008, 08:18 AM
should you be getting the test light to come on when you touch the red wire connection and if yes what could the problem be? when I touched the wire the ingnition was 3/4 of the way on. I get not light when I touch the wire but I am getting light when I touch other connections so I know I have good ground.
Old 09-28-2008, 08:24 AM
Engine_HP's Avatar
https://ls1tech.com/forums/showthrea...453&highlight=
Old 09-28-2008, 08:25 AM
Engine_HP's Avatar
is there any problems reading the ECT ?
Old 09-28-2008, 08:49 AM
I have the connecter, does the alternator ground need to be grounded for a + test light when you touch the red wire connection?
Quick Reply: engine code p1637
