How do I tell which Pin is which?
Old 09-24-2008, 02:37 PM
98 WS6's Avatar
Default How do I tell which Pin is which?
Alright, so I know nothing about the PCM. I need to find Pins 65 and 66. How am I supposed to find these by looking at the PCM?
I need them to install a narrowband A/F gauge.. and I need to find the purple O2 sensor wire.
Thanks!
Old 09-24-2008, 03:09 PM
12secSS's Avatar
It is marked on the connector itself. Simply lift off the palstic cover (careful as it can break) and you will expose the pin locations.
Old 09-24-2008, 03:25 PM
2002_Z28_Six_Speed's Avatar
The numbers are very small and the pcm connector might have dirt on it. you might have to clean it with a nylon brush to reveal the numbers.
Old 09-24-2008, 04:11 PM
98 WS6's Avatar
Do I take the two bolts out from the top of the PCm, then take the gray cover off to see these numbers?
