I dont know if this goes here but i got a big problem need h
Ok All i did was move the ground wires no when i turn the key on the left turn signal is working but is not really turned on.When i turn it on it says low traction and abs in op.Any ideas on what wrong? PLease i need some help
Re: I dont know if this goes here but i got a big problem need h
Sounds to me like you have some wires shorting out. or one of the grounds came loose look around were you moved the wires and see if you can find a bad connection or a bare wire that could be grounding against somthing.
i was typing as u where i went back out and tightend one bolt and bam perfect thanks
I don't know if it's true, but there is a story about the first 'vette that was ever built was going to be fired up for the first time by some big-wig in the company . . . the ceremony came to an embarrassing end when the motor wouldn't crank due to the electrical system being grounded to the fiberglass body!
Beware of this with a 4th gen Fbody also . . . if you have an SS, the only metal body pannels are the two rear quarter pannels . . . something to think about when relocating grounds for what ever reason.
