Project XTA Build - (SuperLow)
Old 02-09-2009, 08:06 AM
JasonWW's Avatar
Default Project XTA Build - (SuperLow)
I'm going to start a build log here if you guys dont mind.
This is my regular car that I've had for about 6 years. It used to be my daily driver. I'll call him Blackie. (99 Trans Am)
Now I had planned to do lots of extensive mods to this car, but it snowballed to the point that I decided to build a whole new car and leave Blackie alone.
So I bought this one. This is my test mule/project car. I'll call him Whitey. (98 Trans Am)
List of mods planned:
1. Custom front suspension consisting of shorter aluminum spindles and new upper control arms. The shock towers will be completely removed.
2. Custom independant rear suspension with tubbed wheel wells. It will be a short arm/long arm independant rear suspension setup with a Ford 8.8 IRS diff. I may mount the trans in the rear as well.
3. Choptop. Lowered roofline with removable roof, cut down front windshield, and custom made side windows.
The goal is to be able to set the car down on the ground with the air suspension and have the total height be 38" or even less if possible.
Now if worst comes to worst, I'll just use Whitey as a testbed for certain mods which will then be transfered to Blackie. For instance, if I lose interest in Whitie, I can transfer the front suspension setup over to Blackie. If I build a new roof and side windows and get the front glass cut, then it should make things go real fast to give Blackie the chop top. You get my point?
This will be a slow build so please don't ask me if there are updates.
Old 02-09-2009, 08:40 AM
JasonWW's Avatar
Here is a list of older links if your interested in certain portions of the build.
General thread of all the stuff I want to do
Figuring out a mid-engine design
Converting the stock unit body car to a space frame design
Short spindle conversion
Choptop info
Adding airbags
Radiator relocation
I've already done the front breather conversion.
Fixed projector HID conversion
I've been working on and off for a while on these. I now have all the parts.
Old 02-11-2009, 05:20 AM
sway99bird's Avatar
Dang you are actually doing it I can't wait to see it done
Old 02-11-2009, 08:55 AM
JasonWW's Avatar
I'm going to build something. I don't know if I can do everyhing I want.
Old 02-11-2009, 11:09 AM
Spd-Kilz's Avatar
This is going to be awesome. Please keep us updated.
I've always loved your out-of-the-box ideas. If this actually comes together, it will be badass!
Old 02-11-2009, 10:32 PM
4WOFURY's Avatar
+1. You have some badass ideas, I can't wait to see them become a reality.
Old 02-12-2009, 01:40 PM
TORCHD 02 TA's Avatar
you have had some crazy ideas. Can not wait to see what it looks like
Old 02-17-2009, 12:18 AM
sporty_drew's Avatar
I'll be watching. Good luck
Old 02-17-2009, 12:49 AM
JasonWW's Avatar
I hope to have the roof off and shock towers out in the next day or so.
Old 02-19-2009, 07:16 PM
JasonWW's Avatar
An update.
I added some wheels so I could move it around.
I cut the nose off to make it easier to cut the shock towers. I'll get those off soon.
Old 02-19-2009, 07:21 PM
slammer454's Avatar
looks good so far Jason, i bet the neighbours must absolutely love you.
Old 02-20-2009, 08:38 PM
ws6in's Avatar
your neighbors must love you haha i live in a strick neighborhood and me being a grease monkey im allways making noise or toying with something and they hate me... im excited to see the finished project good luck man
Old 02-21-2009, 12:50 PM
w3s1c0a5t's Avatar
This is a crazy project sir. Props for at least attempting.
Also what was the main goal of the Mid engine? Just being different? I didnt know if you have some performance idea in mind as well.
Old 02-21-2009, 12:56 PM
3.8redbird's Avatar
subscribed buddy
GL
Old 02-21-2009, 02:15 PM
JasonWW's Avatar
Mainly it was to allow me to raise the k-member 2" so I can really put the nose in the dirt.
Plus it solves the exhaust routing problem.
Plus it would let me put some subwoofers up front for more accurate sound quality.
Plus it would just be cool.
A "proper" transmission would run me about $6k plus clutch and LS1 adapter. That's just too much in my opinion.
Old 02-21-2009, 07:21 PM
w3s1c0a5t's Avatar
Cool man. Should be insane when you get it done. Whats the "IMproper" tranny your setting up
Old 02-21-2009, 07:31 PM
JasonWW's Avatar
There are cheaper mid-engine transmissions out there, but they can't handle much more than 300HP. I was trying to figure out a way to go mid-engine with a tough and cheap 4L80E or T-56. It will probably stay front engined, but I haven't given up on mid-engined, yet.
Old 02-21-2009, 07:43 PM
w3s1c0a5t's Avatar
I dont want to hear it. YOU make that thing mid engine. Also i need it done by june 5 6 7th So i can see it while were down for the cruise.
Old 02-23-2009, 11:58 AM
Demonicbird00's Avatar
look into the factory five gtm car. that is a mid engine ls1 w/ a porshe 6spd trans
-brandon
Old 02-23-2009, 02:31 PM
slammer454's Avatar
actually a half decent idea, maybe call em up and see if they have any advice.
Quick Reply: Project XTA Build - (SuperLow)
