Turn Signal Lever
Old 02-05-2010, 05:32 PM
Tx98Formula's Avatar
Default Turn Signal Lever
ok so i'm trying to replace the turn signal lever on my 98 formula. I have the steering wheel off, the lock plate off, i took the 3 screws that hold the turn signal assembly in and also the screw off the arm that conects the lever to the assembly. i can't get the assembly out of the column ( i also removed the hazard switch) it feels like something is connected to it holding it back but i can't see where to disconnect anything...
has anybody removed all of this before? anyone have any ideas at all or can tell me what i am doing wrong?
thanks
Old 02-08-2010, 12:06 AM
mannyman84's Avatar
thanks
Sorry man. I've never taken apart mine. Have u tryed YouTube? Lol
Old 02-10-2010, 10:13 PM
bigj2717's Avatar
Why would you even reply if all you have to say is check out youtube
Im not too sure to answer your question when i did mine i had a donor column so i got fet up with all those little parts and just swapped the whole column took all of 30 minutes.
Old 02-11-2010, 08:04 PM
yeah i got it all figured out.. all you basically have to do is pull a little harder then i originally was.... all that work for that...
Old 02-11-2010, 09:40 PM
mannyman84's Avatar
because there are some people that would take the time to reply even if they have a suggestion. And others that are rude and just ignore the threads
Old 02-12-2010, 06:33 AM
That's MISTER MODERATOR
Paul Bell's Avatar
And some people post meaningless drivel to get their post count up.
Old 02-12-2010, 11:14 AM
mannyman84's Avatar
lol..i care less about the post count, i get nothing out of it, u know!!
Quick Reply: Turn Signal Lever
