water in rear
Old 08-31-2010, 11:14 PM
blaktrans's Avatar
Default water in rear
Really need help, every time it rains pretty hard, I get water collected in the rear where the T-top storage is on my 2002 trans am. How and why? anyone else have this problem?
Old 09-01-2010, 07:20 AM
EchoMirage's Avatar
guessing hatch seal is bad. see if the weather stripping is broken, rotted, or pinched anywhere. if it is, fix or replace.
just for an off shot, check under the carpet or underneath the car, and see if any of the plug looking things in that area are loose or missing.
Old 09-01-2010, 07:28 AM
zachrywd_01TA's Avatar
How long have you owned the car, has it ever been in an accident? I had a Grand Am that was rear ended and after that accident I experienced a similar problem with the trunk getting wet.
Old 09-02-2010, 10:02 PM
formula vincent's Avatar
check the area where the tailight housing mates to rear quarter panel some of the caulk seal
on the edges may have come off causing water to seep in .
Old 09-15-2010, 02:55 PM
jerri311's Avatar
Check the plugs underneath the car. Same thing was happening to mine and one of those plugs were cracked.
