This might be a dumb question.
How the hell do i get to the foglights to replace the bulbs? I see the bumpers held up by the plastic pieces, but i dont want to pry them off, can i take it out the front? I feel really dumb considering how mechanically inclined i am but i dont wanna screw anything up.
Wear safety glasses as there will be dirt and debris in there.
There are three plastic clips that you need to pull out.
Pull with pliers or pry with an upholstery tool or flat blade driver the center bit out,then pull out the whole clip.
Pull back the plastic bumper and the plastic rad deflector and reach in and turn the bulb to unlock it.
Pull the whole harness and bulb out to where you can see it, remove the old bulb and reach back in trying not to touch the new bulb as you line it up to twist lock it back in.
Change both while your in there.
Put everything back in place
