Cruise control '99 T/A
Old 01-16-2011, 07:40 PM
sceld71's Avatar
Default Cruise control '99 T/A
My cruise control does not work. Its a '99 T/A with an automatic. I've already checked the fuses on the dash and under the hood. None of them were broke. Any suggestions?
Old 01-17-2011, 12:11 PM
323steel36's Avatar
check fuses. next to driver side if any of them are damaged. or can be that one of the wires the connects your cruise control and controls windshield wipers is not getting a full circuit. could be a damaged wire. good luck.
Old 01-17-2011, 02:57 PM
Hartje's Avatar
Check the cable on the throttle body too, make sure that its still hooked up could be something simple, or it could be a real bitch. like the above post, it could be the wires in the steering column. Electrical gremlins suck!
good luck
