Headlight issue?? help!
My driver side headlight is making an awful grinding noise once the lights are turned off. I'm not sure what the problem is because the headlight goes up and down without a problem. The noise is like delayed a couple of seconds. It's almost like the motor will not disengage. So I had to pull the fuse and leave the driver side light up. Is there a relay or something that tells the motor to stop? or is the motor/gears bad?
