LS3 swap questions
LS3 swap questions
Do I have to use a corvette ignition? or can I use a LS1 firebird/camaro ignition? or even the VATS ignition? I've never done anything like this before, and I'd like it to work
youll need a different oil pan, a 24x reluctor to swap on the crank, and an aftermarket 4 bolt DBC throttle body.
i think you have to extend your knock sensor wire as well.
all your wire harnesses and front accessories will swap right onto the ls3
