Fan help 99 formula
Fan help 99 formula
I got a problem with the fans. They dont come on by them selves and the only time they come on is when the air is on. I replaced 3 relays and checked the 10amp fuse. No change, so I googled the problem and found some people fixed this with changing the temp sensor on the drivers side head. I did that and still the fans will not come on. I wired both fans to the batt to test them and they both work fine. I am at a lose and need some help from somebody that knows more about these cars then me.
