Help with 02 TA parts value
I recently bought a 2002 WS6 Trans Am donor car, I'm going to be parting out everything I don't need and I would like some help with the value of a few parts. The car hit a wall on the RR and spun into the wall with the RF…….the Ram Air hood inner structure is split from the front back through the latch area…….it appears to be an easy fix, the split is limited to the inner structure and not the surface of the hood. There is very minor damage on the edge of the hood near the right "scoop", again, a very easy repair. The stock ram air filter assembly is there too and I plan to sell it all together.
The bumper cover is probably repairable too, but it won't be as easily repaired, so I mainly focused on the hood and air box value.
Any idea on what it's worth??
I also have the rear hatch that has very minor damage on the RR corner and the RF corner, again, an easy fix. Value??
Here are a couple of additional photos of the car. I will be glad to take photos of specific parts if necessary.
You can see the minor damage on the RR corner of the hatch. The RF corner has similar damage……easily repaired.
Parts are located in the Tulsa, OK area.
