Turn Signal Problemo
02 WS6: Came into work this morning and right signal decided not to work. I checked the front drl and it was on, which was a surprise to me. Will the signal stop blinking if a rear light is out? It was bright out and I could not tell if any rear lights are out but it does not appear so. I've read a few posts about solid signals and nothing seems to match exactly. Where should I start here, can't be a fuse can it? I would think they would all go out if that was the case. The left signal working fine.
Thanks jerid, I didn't have time to change the bulb when I got home but I'll try in the morning to see if it fixes her up. Had no idea about the dual filament.
Would it still be the relay if my left signal still works? Also I've noticed that on the non working right signal after I try to use it and pull the signal arm back down on the column, the drl/signal will briefly turn off. Getting weirder...
