2002 ws6 front lights bumpers ?
First of all I'm not sure of the technical name of the part I'm looking for.
Basically, it is the white little "bump" that seats behind the front headlights and when you turn off the lights, the headlights stop on this little plastic part.
I am missing one of those and was wondering where I can find it please ?
I went to GM but the guy couldn't find it with his computer.
Thanks for your help guys, if you need a photo, let me know
Save the manuals!
They can't be had.
The fix is to cut off a short piece of rubber hose and put it on the stop in place of the white plastic piece. It actually performs much better. Just get a piece that fits really tight.
Holds better, lasts longer, less noise when the door opens/closes, etc. I wish I had found the trick earlier on in my car's life.
Oh that's a good idea actually.
At first, I put some rubber that you put under chairs so they won't make noise on the floor lol Works pretty well also but doesn't look good and with time it got bent a little bit.
I'll try with the rubber hose
Thanks again
Also, could you post a photo so I can see how you installed it please ?
Thanks again
