Brightest possible bulb for factory 4th gen ta as title says looking for hughfoglight
Looking for the brightest possible bulb to fit in a stock foglights on a 4th gen ta, doesn't have to be dot legal it's for a drag car with the headlight away removed. Cost is of little concern will be running on 16v
I bought a couple for my Formula Fogs. They are 1000 Lumens without the heat.
John
Here's the SuperBrightLeds.com P/N:
880-HLV3-M
White 6200K 1000 lm
John
The 880 LED bulb simply plugs into the stock harness. The 3 copper braid heat sinks are located outside the lamp housing, and you spread them out so they can dissipate heat. There is plenty of room to do this.
SuperbrightLeds.com 880 Fog Light Bulbs:
Here's my list of all the lights I replaced on my '99 Hawk:
Super Bright LED’s:
Brake Lights 3157 3157-R26-CBT Red 26/100 lm (These didn't have enough contrast between running lights and brake lights)
Brake replaced by: 3157 3157-XHP28-T-CAR Red 17/96 lm
Outer Tail Lights 194 WLED-R5-CBT Red 85 lm
Backup Lights 3156 3157-W26-CBT White 500lm
License Plate 194 WLED-NWHP5 White 90 lm
Rear Side Markers 194 WLED-R5-CBT Red 85 lm
Rear Dome 212-2 RL4410-NWHP9 White 50 lm
Glove Box 194 WLED-NW13-CBT White 170 lm
Front Side Markers 194 WLED-A5-CBT Amber 85 lm
Front Turn Signals 3157 3157-A45-T Amber 300 lm
Fog Lights 880 880-HLV3-M White 1000 lm
New Electronic Turn Signal Flasher, Stock 4-Way Flasher.
New Front Turn Signal Housings
3M Film by Autographics on Front Turn and Fog Housings, &Tint on
front side markers.
Notice the Oriental Rug? My Ex loved seeing that rug in my living room. My new wife loves seeing it in the garage
John
'Bird Director
Not bright enough for what you're after, but I borrowed the L.E.D. idea from Mike Brown's old Firebird. 12" strips stuck to the backside of the headlight doors. My "headlights" were the closest size I could find other than the stock driving lights. I trimmed out the bottom of the openings in the bumper cover so they'd fit.
I backed the Hawk out of the garage as much as I could without letting it roll down the driveway.
Super Bright LED’s:
front side markers.
John
Super Bright LED’s:
front side markers.
John
Is that a Formula Firehawk? sure don't see them around, probably because they are rare.
Save the manuals!
This is plug-n'-play, but if you want to do a little modding and "turn it up to eleven", then this thread should give you the paths forward: https://ls1tech.com/forums/pontiac-f...-s-coming.html
Here is a hid kit in my stock fog light housing. To bright to have on at night in traffic so I just run them during the day and at dawn which I think they look wicked.
This is a link to the ones I'm running https://www.amazon.com/XENTEC-6000K-.../dp/B006LJ1W9M and a picture of them at night.
