78 t/a power windows question
hey, i have a 79 trans am that i turned into a 78. I have shorted the power wire that goes to the power windows and i am just wondering if its a fuse or circut breaker? ive searched the fuse box and no blown fuses if its a CB, where is it located? thanks
Yep, power window switch is very common to go out. Pull it out and test it. Replace if needed - they're cheap. Also, try this link for wiring info:
http://www.firebirdtransamparts.com/...ss/harness.htm
Really good info for researching your car. Good luck!
