How to manually lower/raise headlights (1998-2002)
When you lift the hood there will be a little hole near the headlight about the size of a half dollar... If you look in there it has a dial you can turn to raise or lower the headlight. Kind of like an LT1, just not exposed.
Sorry if the description is terrible, I don't have a pic unfortunately.
Copy & Paste Moderator
From memory... There is a round hole in the brace behind the headlight. When you look in, you see a rummer cap with a thin cylinder standing on top. Remove the rubber cap. You'll see a ****. Turn it to raise/lower the headlights.
