Pontiac G8 2008-09 & Chevrolet SS 2014+ LSX based RWD 4-door sedans
Memphis 16-MC100D Amp and Power Acoustik Corssover
Old 09-08-2011, 12:14 PM
blackpala96's Avatar
Default Memphis 16-MC100D Amp and Power Acoustik Corssover
Used, but in good condition. The Amp is all pre-wired and ready to be hooked up to your subs. As a bonus, there is a Power Acoustik 12Db Active Cross-over wired in with the amp.
$300 OBO
text: 8157185534
Description: of the amp
* 1100W RMS Class-D Monoblock Subwoofer Amplifier
* Custom Black Pearl Finish
* Fully Variable Low-Pass Filter: 50 - 250 Hz, 18 dB/Oct
* Variable Subsonic Filter: 20 - 50 Hz
* Bass Boost: 0 - 18 dB
* Gold-Plated RCA Connectors
* 4 Gauge Power Wire Capability
* Wired Remote Gain Control
* Power and Protection LEDs
* Thermal, Short Circuit, and Overload Protection
* RCA Outputs: 1 Pair
* Adjustable Input Level Control: 400 mV - 4V
* Damping Factor: 300
* DImensions: 13.4" L x 6.25" W x 1.7" H
* 1-year Sonic Electronix warranty
Amplifier Specifications:
* Amplifier Class N/A
* Number of Channels 1 - Mono
* RMS Power (4 ohms) 300 watts x 1 channel
* RMS Power (2 ohms) 600 watts x 1 channel
* RMS Power (1 ohm) 1100 watts x 1 channel
* Bridged RMS Power Not Bridgeable
* Peak Power Output 2200 watts
* Minimum Impedance Unbridged 1 ohm
* Minimum Impedance Bridged Not Bridgeable ohm
* THD at Rated RMS Power 0.75%
* Speaker Level Inputs No
* Amp Preamp Outputs Yes - 1 pair
* Built-in Crossover LPF(50 - 250 Hz), Subsonic(20 - 50 Hz)
* High-Pass Crossover Frequency
* Low-Pass Crossover Frequency
* Subsonic Filter
* Signal-to-Noise Ratio 95 dB
* Channel Separation N/A
* Bass Boost 0 - 18 dB
* Bass/Gain Remote N/A
* Fan Cooled N/A
* Fuse Rating 40 A x 2
Quick Reply: Memphis 16-MC100D Amp and Power Acoustik Corssover
