Lifter tick
It can lead to dod lifter failure (very common). I just got my car back from the dealer because of the same issue. It started as a lifter tick and turned into a misfire on cylinder 6 (the dod lifter was stuck closed and wasn't making contact with the pushrod to open the valve). I would have it looked at now, especially if your still under warranty.
Should still be covered under warranty but if I have to crack it open to put a lifter in it I want to do away with the DOD stuff and put a mild cam in it while I'm in there. Just wondering if it's something I should take care of now? If the lifter(s) do fail, is it gonna be more damage than just the lifter?
This is impossible to answer. I got very lucky as the lifter didn't break into pieces, rather just get stuck closed. Why take the chance if it's covered under warranty? I had the same idea in my head but at the end of the day, I didn't lay out any money and my car is now 100%. If I decide I want to swap the cam in a week or a year, at least I know my car didn't have any issues prior to the install.
Won't get better over time, that's for sure. I had the lifter tick in my car back around 15k miles. Would only do it for a second or two on cold start ups, then went away. Around 20k miles it was worse.
I would bring it to the dealer. Bad lifters can beat up the cam. There's a TSB for this problem. Mine were replaced under warranty (with an improved design lifter.) Not a single tick since then and I'm at 61k miles.
Or, do a DOD Delete/cam swap and put a real cam and real lifters in it
