Spark plugs/ Spark plug wires/ Transmission fluid questions
Is AC Delco 41-110 the correct replacement spark plug?
Is AC Delco 748UU the correct replacement spark plug wire set?
Is GM part number 88864060 a good replacement fluid?
Thanks guys/gals!
Thanks guys/gals!
I believe I used this on my built trans and Coan converter - http://www.walmart.com/ip/Valvoline-...allon/15125768
I think this is the synthetic version, it came highly recommended from the trans builder. No issues after multiple drag runs
It's not mine! woo hoo!
Late to post here, but figured I'd add the info for posterity...
ACDelco 41-110 is the correct, OE iridium plug.
ACDelco 748RR is the correct wire. It is the 90* end and is also red. 748UU is black and is the straight end. It will work, but it's not the wire.
ACDelco 10-9030 (88861954) is the correct DEXRON VI transmission fluid.
